Old     (trio)      Join Date: Jan 2010       10-28-2010, 9:42 AM Reply
Does anyone do their own service? What is entailed with the 100 hour dealer service? What type, brand and weight oil do you use in your boat?
Thanks!
Old     (dlamont)      Join Date: Apr 2003       10-28-2010, 10:08 AM Reply
We use Pennzsoil 15w40, change the cap/rotor, spark plugs, flush transmission, change trans filter, change impeller. I think that's about it.
Old     (gti2lo)      Join Date: Nov 2005       10-28-2010, 10:13 AM Reply
I was thinking of moving to AMSOIL or so but the factory pennzoil hasn't shown any signs of "use" even after 100 hours.
No drop in oil level and fairly clean after a 80 hour season.
Old     (Donski)      Join Date: Mar 2010       10-28-2010, 10:41 AM Reply
Rotella 15w40, impeller, and in tank fuel filter.
Old     (acurtis_ttu)      Join Date: May 2004       10-29-2010, 7:49 AM Reply
I use chevron 15w40 and wix filters. change every 50-75 hours.
Old     (blake_hughes)      Join Date: May 2004 Location: Weatherford, Texas       10-29-2010, 3:30 PM Reply
I use this stuff in my engine and v-drive... Recommended to me by many.
Old     (coz)      Join Date: May 2008       10-29-2010, 7:14 PM Reply
Wasn't it you that asked this very question on Team Talk?
Old    mojo            10-29-2010, 9:35 PM Reply
2.4 What type of oil should I use? Can I use synthetic oil?
Indmar recommends (and uses at our factory) Pennzoil Marine 15W40 Motor Oil. If Pennzoil 15W40 Marine Oil is not available in your area, we suggest using 20W40 or 20W50 oil meeting the API specification of SJ/CG4 or better.
Synthetic oil that meets our requirement of 15W40and API rating of SJ/CJ4 is acceptable to use after 100 hours or operation with the recommended (not synthetic) oil. The use of synthetic oil does not alter the requirement for oil changes at 50-hour intervals.
Older operator manuals, and other publications that are not regularly updated will not be revised to show this latest engine oil recommendation. Current operator manuals, and other service publications that receive regular updates will receive this revised recommendation the next time they are updated.
Old     (trio)      Join Date: Jan 2010       10-29-2010, 9:56 PM Reply
Yes. I put up the same post on the MC forum also. Why do you ask?
Thanks for the feedback guys!
Old     (xstarrider)      Join Date: Jun 2007       10-30-2010, 11:12 PM Reply
Rotella 15W40. Can't beat the price/quality.
Use Napa Gold Filter
Old     (coz)      Join Date: May 2008       10-31-2010, 6:21 PM Reply
Oh....just wondering because you got the same answers over there.
Old     (njskier)      Join Date: Jul 2005       10-31-2010, 7:59 PM Reply
Same here, NAPA 1069 filter and Rotella 15W40 oil. Same oil for the trans too.
FYI, 100 hours between oil changes is a bit too long. I change mine every 50 hours (twice a year)
Old     (consigliereg8r)      Join Date: Aug 2009       11-01-2010, 5:02 PM Reply
my family used to own truck stops and we sold Rotella and Dello 400 for semi's. That is what I use in my boat, Rotella. It was what was recommended by my dealer, Nautiques of Orlando.
Old     (talltigeguy)      Join Date: Sep 2003       11-01-2010, 8:19 PM Reply
Isn't the recommended oil different based on which engine you have? I am surprised that hasn't been asked yet.
Old     (coz)      Join Date: May 2008       11-04-2010, 8:36 AM Reply
Read it for what it's worth http://indmar.com/About/ContactIndma...Presentweb.pdf
Old     (talltigeguy)      Join Date: Sep 2003       11-05-2010, 6:04 PM Reply
From the manual: Indmar uses and recommends Pennzoil Marine 15W40 in all 5.7L, 6.0L and LS7 engines and Pennzoil Heavy Duty 40W in all 6.2L (383), 7.4L (454), 8.1L (496) and 8.2L (502) engines. This oil meets the API Service CI-4, CH-4, CG-4, CF-4, and CF/SL. If engine is to be used in conditions below 20 F (-7 C), use Pennzoil 10W30 meet- ing the above API specifications.
Most importantly, the MCX uses different oil than the LY6 or 8.1. Can't believe that he got all those answers without knowing what engine he has.
Old     (razzman)      Join Date: Dec 2006       11-05-2010, 8:00 PM Reply
Well for what's it's worth I talked with TJ @ Indmar yesterday about something else. I then asked about their oil recommendations, his answer? "It doesn't really matter what oil you use as long as it's a quality oil that meets or exceeds the API rating. So in other words weight is not as important as the API rating, so use what you want". That help any?
