I just barely thought of this idea. Hopefully it does not sound too crazy. I am sure that it will be more expensive and difficult to make though.
problem with current designs: I have seen fins crack and break where the screws go through the fins because the material is soo much thinner there
I was thinking that the screws could instead become shafts that are A PART of the fin. They could be machined as all one piece with screw threads on the top. The fin's shafts could be inserted up through the bottom of the board and then bolts could secure it from on top.
the attached illustration: i did a quick picture to illustrate this. I know the fin is huge and looks more like an old school fin, but just look at it for the idea. I colored the fin blue to emphasize that it and the shafts are all ONE piece. and the two little eyeball-looking things are the bolts up top.
advantages i see: 1. the fins would be less likely to break without pre-made holes weakening the body
2. with this design more shallower fin depths that were thought to be unachievable could be made, because the bolt no longer has to screw into the fin. Thinner fins could even be made (ouch)
3. this is more of re-emphasis of 1 AND 2. the fins would be more slider friendly
disadvantages i see: 1. the bolt securing the fin on the top of the board would have to be bigger, potentially creating a bit of an eye-sore
2. more expensive and harder to make
3. less universal of a fin design. it would be more specific to one brand of board
tell me what you think?
(disclaimer: i am no expert when it comes to manufacturing)
