At your size and weight, either option is fine. HOWEVER If I were you, I'd just keep the watson and move the boots in. You'll benefit from the greater surface area through bigger pop and softer landings, and get used to the stance or just move it in further again. I'm assuming that you're still young?so if that is the case you will probably need the bigger board over the coming year.
Reason: Assumption may be wrong...
