Old     (needwake)      Join Date: Nov 2005       04-11-2008, 5:54 AM Reply
I want to give the carpet a good clean before the beginning of the new season. I always vacuum it but has anyone pressure washed their carpet first and then shop vac it? I was also thinking about renting a steam cleaner. Which do you think would work better?
Old     (acurtis_ttu)      Join Date: May 2004       04-11-2008, 7:31 AM Reply
pressure washer, used it on my 04 SSV, worked great.
I sprayed some pre-soak carpet claner stuff from a local detail shop on it first and let it sit for 30-45 min, before I washed.
Old     (jmanolinsky)      Join Date: Dec 2005       04-11-2008, 8:09 AM Reply
I just finished pressure washing mine. I left the boat out in the sun for a day to dry before putting it back in the garage. Steam would probably not be a good idea. A steam cleaner will cut through asphalt like butter. I'm sure it wouldn't be good for the carpet or adhesive holding it down. Adam's method sounds good.
Jman
Old     (tlatoani)      Join Date: Oct 2007       04-11-2008, 8:26 AM Reply
wet/dry vac helps it dry faster.
Old     (slowjet)      Join Date: Aug 2007       04-11-2008, 8:40 AM Reply
I pressure washed mine Sunday and left it out to dry like Jman. It looks good. One of the benefits was that I could spray in the ski locker where I wouldn't be able to vacuum. I'll probably still rent one of those carpet cleaners a little later though.
Old     (taylormade)      Join Date: Jun 2001       04-11-2008, 9:03 AM Reply
add a little bit o' fabric softener to the water bucket and scrub with a soft bristle brush (push broom), pressure wash with the fan setting (instead of the hole blasting setting) and then shop vac/sun dry... my 04 MC looks good as new after it.
