I would also do a perko switch with your two batteries. The perko switch has 4 settings, battery one, battery 2, battery 1 & 2, and off. The reason for this when stop at the sand bar, you can turn on the radio and you can set the switch, so it just pulls juice off of battery one, so after a couple cold ones and some good scenary, the radio dies. With the perko switch you can switch to battery 2 and the boat will still start. You will be amazed how fast the batteries will drain with 2 amps and the music cranked, it doesn't take long. I will never have a boat with out 2 batteries in it, and I buy bigger batteries than what I need as well. And then at the end of the day, you can hit the perko switch to off and no power can be drained while your boat sits. I wire my stereo head unit directly to the battery, so I don't lose my settings, but all the power for everything else comes out the perko switch. Also spend the extra 15 bucks on the switch that has the protection switch on it, that if someone tries to change while the boat is on (which is really bad) just my 2 cents...
