Cut and paste special:
What is the Reserve Capacity rating (RC)?
The reserve capacity of a battery is defined as the number of minutes that it can support a 25 ampere load at 80°F until its terminal voltage drops to 1.75 volts per cell or 10.50 volts for a 12V battery. Thus a 12V battery that has a reserve capacity rating of 100 signifies that it can be discharged at 25 amps for 100 minutes at 80°F before its voltage drops to 10.75 volts
What is the CCA rating?
The cold cranking ampere (CCA) rating refers to the number of amperes a battery can support for 30 seconds at a temperature of 0°F until the battery voltage drops to 1.20 volts per cell, or 7.20 volts for a 12V battery. Thus, a 12V battery that carries a rating of 600 CCA tells us that the battery will provide 600 amperes for 30 seconds at 0°F before the voltage falls to 7.20V.
What is the Amp Hour (Ah) rating?
An amp-hour is one amp for one hour, or 10 amps for 1/10 of an hour and so forth. It is amps X hours. If you have something that pulls 20 amps, and you use it for 20 minutes, then the amp-hours used would be 20 (amps) X .333 (hours), or 6.67 AH. The accepted AH rating time period for batteries used in solar electric and backup power systems (and for nearly all deep cycle batteries) is the "20 hour rate". This means that it is discharged down to 10.5 volts over a 20 hour period while the total actual amp-hours it supplies is measured. Sometimes ratings at the 6 hour rate and 100 hour rate are also given for comparison and for different applications. The 6-hour rate is often used for industrial batteries, as that is a typical daily duty cycle. Sometimes the 100 hour rate is given just to make the battery look better than it really is, but it is also useful for figuring battery capacity for long-term backup amp-hour requirements.
The main advantages of purchasing a "Smart" charger are:
>The smart chips allow you to safely fast charge your batteries without worrying about overcharging them. Smart chargers will charge your batteries more consistently because they can sense when your batteries have reached a full charge by measuring the voltage rise and change. They will then switch to a trickle charge which will keep the batteries fully charged until use.
>The smart chips also protect your batteries from overcharge and overheating which will extend the life of your batteries. Our smart chargers also have a "conditioning" feature which when used occasionally will keep the internal chemistry of the battery in top condition by reducing the internal resistance of the battery which will result in increased capacity and run times.
