Old     (openwydr)      Join Date: Aug 2004       07-15-2007, 6:55 AM Reply
The PP on our 2005 Xstar has started to surge. It is not holding speed very well. It is about a 2-4 mph surge. Very dif to ride behind. Any one have this problem? How do you resolve this? This is the first time it started doing this. Last year we never had any issues with it. We did go to a new prop this year ( Acme 4 blade) but acme and the dealership told me tha ithis would not affect the pp.Thanks
Old     (65sanford)      Join Date: Feb 2007       07-15-2007, 7:39 AM Reply
Go to www.perfectpass.com and check the troubleshooting area. My install manual does have conditions and fixes pertaining to this type of issue. Good luck--probably a minor issue
Old     (mitchj)      Join Date: Aug 2002       07-15-2007, 10:47 AM Reply
change the prop and it will go away had the same problem this year on my MC when I went to a 14 1/4 x 14 3/4 . I put it back on the lift and put on a 14 1/4 x 14 1/2 and it went away just for drill i put the 3/4 back on and the surging came back ,the dealership is not correct . I am not saying it cant be adjusted out but for sure to much pprop will surge under a load with PP
Old     (cyclonecj)      Join Date: Jul 2001       07-15-2007, 10:56 AM Reply
You probably need to retune PP for the new prop is all. See the PP docs for info on changing NN and KDW.
Old     (openwydr)      Join Date: Aug 2004       07-15-2007, 11:07 AM Reply
We usually run with an extra 1000lbs.
I reset the NN to and KDW to 150, what does every one have them set at?
Old     (krbaugh)      Join Date: Mar 2002       07-15-2007, 11:44 AM Reply
It can also be a perfect pass problem
they are great people and will help you
drop them an email or give them a call
http://www.perfectpass.com/
Phone (902) 468-2150
Fax (902) 468-8837
E Mail the Sales Dept: sales@perfectpass.com
E Mail Tech Support: techsupport@perfectpass.com
E Mail Randy Eisener: randy@perfectpass.com
Old     (hdrew)      Join Date: Sep 2004       07-15-2007, 12:22 PM Reply
Mine was doing the same thing. The manual said that it could be because of debris in the paddle wheel. It was kinda weedy that day, so when we pulled out, I got under the boat. I didn't see anything, but I did spin the wheel a bunch and problem was gone.
