Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 07, 2006
Old     (qtybry)      Join Date: Nov 2002       10-24-2006, 4:49 AM Reply
hello
my board got damage at the slider it has a crack on my in board fins.
whats the best material should i used recine, marine epoxy etc? i heard marine epoxy will crack again.
Old     (tylerc)      Join Date: Jun 2006       10-24-2006, 4:56 AM Reply
I can't speak too much of ways to repair the bottom of the board, however when I cracked my topsheet, I used a product called SunCure to fill it in. Worked super well. Just a thought.
Old     (sbt3)      Join Date: Jun 2002       10-24-2006, 5:57 AM Reply
I have used marglass which is a fiberglass bondo. It seems to work pretty well and can be easily sanded smooth again. You can get it at autopart stores.
Old     (otiswunguy)      Join Date: Apr 2002       10-24-2006, 7:43 AM Reply
I just use bondo if you have to fill anything. On a few boards I have, I have completely rebuilt the fins with bondo after they were shredded off. If it is a crack then you should use some sort of 2 part epoxy or like sbt3 said with the marine fiberglass.
Old     (slipknot)      Join Date: Aug 2001       10-24-2006, 7:48 AM Reply
JB Weld, from auto parts store
Old     (bvdievent)      Join Date: Nov 2005       10-24-2006, 8:31 AM Reply
I cracked the edge of my board about a month ago and repaired it with a 2 part epoxy. Ive ridden it a bunch of times since and have had no problems. I got it from west marine...heres a link.
http://www.westmarine.com/webapp/wcs/stores/servlet/product/10001/-1/10001/33621/10001/96/11160/4
Old     (wakegenie)      Join Date: Sep 2006       10-24-2006, 2:54 PM Reply
May be this will work: http://www.buywake.com/catalog/detail/RA_8738
Old     (qtybry)      Join Date: Nov 2002       10-26-2006, 1:42 PM Reply
ok thanx guys!!!
Old     (qtybry)      Join Date: Nov 2002       11-04-2006, 12:18 PM Reply
Old     (texastbird)      Join Date: May 2003       11-04-2006, 1:10 PM Reply
PC7 is a nice 2 part epoxy putty that I have used with good results to fill and patch boards. You can find it at hardware stores.
