Old     (gwnkids)      Join Date: Nov 2003       09-27-2007, 7:57 AM Reply
Anyone else have this problem?
With the wake-board in the upper slot the surf-board will hits the bindings, also the rack touches the wake-board
Old     (leaks)      Join Date: Oct 2005       09-27-2007, 9:06 AM Reply
Can't you just turn the board around so the bindings are on the outside??
Old     (locwakeoutlawscom)      Join Date: Apr 2007       09-27-2007, 9:18 AM Reply
Do you have the WB in the strap-on?
Old     (gwnkids)      Join Date: Nov 2003       09-27-2007, 11:33 AM Reply
Sorry guys here is a shot with the wakeboard in the lower slot
Old     (locwakeoutlawscom)      Join Date: Apr 2007       09-27-2007, 12:18 PM Reply
WB's in the top of top rack, bottom of bottom rack. Bindings point up in the top, down in the bottom. Skim/surf in the middles.
Old     (gwnkids)      Join Date: Nov 2003       09-27-2007, 2:03 PM Reply
Will work with the skim but the lower racks forks are too tight to get the walker or the IS blue in.
I have talked to Bryce at dbot about shaving off a little on the bottom of the rack but after paying so much its hard to carve it up.
Old     (smedman)      Join Date: Feb 2006       09-27-2007, 3:12 PM Reply
maybe you can just put some foam tape on the bottom edge of the top rack to protect the wakeboards until you and dbot come up with another solution... won't look as cool, but could be functional...
