Old     (mitch_langfield)      Join Date: Aug 2006       08-09-2006, 4:04 AM Reply
whats the key point to get toe off axis 7s consistant?
at the moment i'm geting really tight line as i land and poping the handle heaps
Old     (fsbiii)      Join Date: Jul 2007       07-31-2007, 8:59 PM Reply
I've been doing toe off 7's for 2 years now and still don't have them consistant and it's the same for all my friends that do them, It takes a while. I have trouble with the handle too, the best trick I know for getting used to the handle pass is to have your driver kink the boat away from you a little bit when you are cutting in, this gives alot of slack to the rope and makes the wake you hit super steep so you get good straight-up pop. After, doing this for a while I was way mor comfortable with where the handle would be and how to get it for that last pass. I also try to almost put the rope on my hip as I am cutting in, this helps alot with the whole handle situation.
Old     (fsbiii)      Join Date: Jul 2007       07-31-2007, 9:02 PM Reply
wow, don't know how I did that, oops
