Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 29, 2006
Old     (kneeboarddad)      Join Date: Sep 2005       08-10-2006, 2:08 PM Reply
My 05 21V won't shut off. Pulled the kill switch, disconnected the battery and finally pulled the wire from the distributor cap. That worked. Restarted and had same problem. Any ideas. The perfect pass and bilge pump were replaced last month if that means anything.
Old     (breadbutta)      Join Date: Dec 2003       08-10-2006, 2:18 PM Reply
You're ignition is getting voltage from somewhere, possibly a short in the harness or ignition switch.
Old     (richmondrider)      Join Date: Apr 2005       08-10-2006, 4:50 PM Reply
Take it as a sign, never stop wakeboarding!
Old     (driving)      Join Date: Jan 2003       08-10-2006, 5:59 PM Reply
I had a wiring harness go bad on my X-Star last year and it did the same thing. It's an easy swap once you figure out which one it is.
Old     (wakedad33)      Join Date: Oct 2005       08-10-2006, 6:10 PM Reply
Travis, are you driving Nationals? I hope!!!! End of hi-jack.
