How are the amps mounted? One mistake that I have seen a few times is that people fasten the amp down over carpet, and then the pile of the carpet blocks the airflow into the amp. You might want to consider makeing small pads at each of the mounting spots to space the amp up away from the floor/hull/bulkhead so that air can flow underneath it. As Bob said, putting a fan to blow across the amps can help a lot. You shouldn't need to blow a lot of air, so you don't need to get carried away. You might even consider tapping into the boat's ventilation system and routing some air via a vent hose to the amps. Just be careful that you don't route water to the amps, they won't like that at all
