If you put a t in the raw water intake and then go to a pump with that line and the line that goes to the block it will mix hot and cold water. Then put a shut off valve in the hot water line and adjust that when boat is up to running temp to let only some of the heated water through the line, you will get a desired temp, and should stay somewhat constant. Then just hook up your pump to a switch and get warmed up.
