Just completed some system upgrades for my '01 SAN and tried it out. I'm stoked about the potential, but have some problems. Both in the garage AND while the engine is running I can't turn it up to any signficant volume as the amp goes into "protection" mode. What I've done thus far is: Sealed sub enclosure with 10" Kicker sub, dual 4ohm voice coils wired in parallel. Kicker 700.5 running boat speakers (upgraded interior Clarions to Sony Xplodes) and sub. I am 90% sure I've got plenty of power to run the sub.. it isn't a mega high-powered job and I giggle at the thump it already provides at low volume. MUCH better than my stock stereo. I'd like to be able to turn it up, tho. I'm running 4 guage wires, both power and ground. Power is directly to the battery (low-end interstate battery, which is probably barely adequate) and the LONGISH ground (~9')is connected same place as my engine starter ground. I went there instead of directly to the batter to save a few feet. I'm thinking first thing to try is a stronger battery (Optima Blue Top) and maybe should be running two? It's NOT a powerful system and I wouldn't think a 700W system should tax a single battery. Anyone have any thoughts what might be causing my my low-volume issue? Maybe the sub should be wired in series instead of parallel so it's running at 8 ohms?
