Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 28, 2009
Old     (chillwiththebrosandkickback)      Join Date: Mar 2007       06-21-2009, 6:11 PM Reply
So I have a 2002 tige 22v rider edition. Its awesome, fully loaded to the max with everything you could need..(yeh not want haha) on it and it has always run perfectly. I understand that the steering for most inboards is though, but mine is a BEAR! A grizzely bear..if you know what I mean NOT the little pussy black bears. Anyway does anyone have any solution to my problem? Its a cable steering set-up.
THanks
Old     (homedawg678)      Join Date: Jan 2007       06-21-2009, 6:16 PM Reply
Yea mine used to be like that as well and we ended up replacing the whole cable. The new cable made the steering perfect, almost like there was nothing attached to the wheel at all.
I am not 100% sure but this is around 150 - 200 bucks so if you really want to fix it, thats the way to go.
(Message edited by homedawg678 on June 21, 2009)
Old     (pri3st)      Join Date: Aug 2007       06-21-2009, 6:19 PM Reply
Not $400-800 bucks. About $150-200. Super easy fix.
http://skidim.com/products.asp?dept=1120
(Message edited by pri3st on June 21, 2009)
Old     (gunnertom4593)      Join Date: Sep 2008       06-21-2009, 6:21 PM Reply
This happened with my buddy's Tige RZ2 and the guys who serviced it last must have tightened something too tight, something to do with the steering. In his case it was the rudder, just took it back up there and it was a quick fix.
Old     (chillwiththebrosandkickback)      Join Date: Mar 2007       06-21-2009, 6:24 PM Reply
Kevin,
What product/solution to my problem are you suggesting with you link?
THanks
Old     (chicagomastercraft)      Join Date: Sep 2008       06-22-2009, 1:27 PM Reply
Sounds like you just need a new steering cable. Approx. a 2-3 hour job depending on the boat.
Old     (andy_nintzel)      Join Date: Sep 2004 Location: Minnesnowda       06-22-2009, 2:19 PM Reply
Yep its a steering Cable, not to hard to fix on your own if you are slightly mechanically inclined. My only suggestion is do it on the water if you have access to a dock because once you get the new cable installed you will have to re-true up the streering wheel.
Old     (dabell)      Join Date: Apr 2007       06-22-2009, 5:29 PM Reply
Ditto on steering cable. Just make sure that you route it above the gas tank. Check out http://www.tigeowners.com/forum/. There are various other boat owners with the same issues
Old     (chpthril)      Join Date: Oct 2007       06-22-2009, 5:50 PM Reply
Steering cable x3 and lube the rudder box a couple time a season.
What kind of water do you run in?
