Old     (bwood)      Join Date: Jul 2003       07-26-2003, 2:23 PM Reply
How should I weight my 2000 mobius v? I have 600 lbs in the center(ski locker)and 250lbs on each side of the engine. That's only 1100lbs and the wake needs more. Where should I add weight and how much?
Old    breakincrazy2            07-31-2003, 8:47 AM Reply
just add weight were you can. To tell when you have enough weight your goin to have to ride behind your boat then if your don't like it or if its not big enough try either adding more weight or just move the weight around. Remember to never weigh down your boat past the capacity.
Old     (n2mywake)      Join Date: Aug 2001       07-31-2003, 8:54 AM Reply
OK that being said, I would consider moving the 250's to the bow and get some 500s for beside the engine compartment.
Old     (timmy)      Join Date: Jul 2001       07-31-2003, 10:00 AM Reply
keep adding weight until the boat won't plane then take a little out.
Old     (jon_a)      Join Date: Feb 2003       07-31-2003, 12:46 PM Reply
Get 500s to go on either side of the engine and put the 250s up in the bow like you said. Keep the locker sack where it is.
