Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 21, 2006
Old     (leblanc1)      Join Date: Apr 2006       04-16-2006, 7:26 PM Reply
Looking for input on what amp would push as set of the ElectroVoice Evid 6.2 efficiently. Of course keeping cost in mind. Thank you.
Old     (acurtis_ttu)      Join Date: May 2004       04-16-2006, 8:03 PM Reply
As I remember they are 8ohm speakers, you could run them in parallel and bridge a mid sized 2 channel amp.
Old     (atropine)      Join Date: Aug 2004       04-16-2006, 9:39 PM Reply
I bought an Audiobahn A8002T on the advice of others here on this board. I think I paid about $170 delivered brand new from an e-bay retailer. Have been using them like this for over a year and they sound great.
Old     (leblanc1)      Join Date: Apr 2006       04-17-2006, 5:33 AM Reply
The Audiobahn A8002T is a 2 channel amp correct? Shouldn't a 4 channel amp be used for this application? The Avionixx AXA800.4 was also recommended.
Old     (malibuboarder75)      Join Date: Jan 2004       04-17-2006, 6:15 AM Reply
Check out the audiobahn a4004t
Old     (talltigeguy)      Join Date: Sep 2003       04-17-2006, 8:03 AM Reply
I loved my Evids...until I melted the tweeters.
I was pushing 250 watts to each speaker at 4 Ohms with a PPI PCX4125, with them run in parallel. There was some confusion on this board about how much power they can handle - 300 watts at 4 or 8 Ohms. I think my experience validates that they can only handle 300 Watts at 8 ohms or 150 Watts at 4 Ohms.
That is a little off topic, but I hope it helps you.
Old     (acurtis_ttu)      Join Date: May 2004       04-17-2006, 9:03 AM Reply
Talltigeguy, remember resistance of each speaekrs stays the same @ 8ohms. An amps wattage will increase as resistance decreases. if you run them in parallel you will show the amp a 4ohm load but will haev to split the wattage by half. an amp that pushes 300 watts into 8ohms will in theroy push close to 600 into 4ohms. I used the a8002t on mine bridged (approx 400 watts RMS) to each pod.....and also had to replace the tweeters.
we might be getting to the same point on this?
(Message edited by acurtis_ttu on April 17, 2006)
