i did the same as george, slightly different design. go to home depot and grab whatever adapters they have (plumbing, sewer, sprinkler systems, whatever) that will take you from a standard hose connection to a felxible rubber piece that you can slip a radiator clamp over to tighten down on your tranny cooler or v-drive. add a cut-off valve so you can control the flow right there if you can.
