then again im wondering if 2 X 6 volts is only good for 55 amp/hours not 110 amp/hour....yes i was wrong, when in series you just double the voltage not the current, when in parallel you double the current. Final answer is: in order for two X 6volts to equal two X 12 volts the two X 6 volts need to start out with double the capacity (IE:110 amp/hours each)
