Its not hard on the tower... or they atleast already thought of it... you need to read more into it ex. this i got in the news section Line Management The WakeKite will come with a special line sheathing and management system to keep the rider free from potential tangling during powered boat operations. As designed, the lines will easily stay clear of the rider when used under recommended safe operations. In over two years of water testing, no line tangling or snaring of a rider has occurred when the boat has been under power, and this includes all water testing activities. There is also a safety-release lanyard in the boat the can be pulled to set the kite free, as well as an automatic line de-coupler that is set into the main tow line. The line de-coupler automatically releases the kite from the boat when "beyond normal use tension" is detected on the line. This weak link de-coupler will release the kite if it snags on something behind the boat, protecting both rider and boat structure.
