Old     (big_xstar)      Join Date: Nov 2004       06-10-2006, 2:53 PM Reply
http://www.wakepics.com/img/19274
sorry for the small video size.
I seem to have it all the way thru except on all mine landings I seem to be heavy on my back foot when coming around to land switch.
Any help would be greatly appreciated.
Old     (garret_s)      Join Date: Apr 2006       06-10-2006, 5:59 PM Reply
+ 2 points for the sweet music in the background.
- 1 point for the total bonerkill grab before the roll.
Old     (garret_s)      Join Date: Apr 2006       06-10-2006, 6:00 PM Reply
Sorry I can't help. I just thought I should let you know that you just netted +1 point in my book.
Old     (canaday)      Join Date: Dec 2002 Location: Hawthorne       06-12-2006, 1:03 PM Reply
You need more weight in your front foot on take off and you need to concentrate on going directly over your back shoulder instead of throwing it out behind your lead shoulder.
Old     (curtbernstein)      Join Date: Aug 2004       07-07-2006, 7:52 AM Reply
i just finished learing my scarecrow. and i can every time now.. Theres alot of different versions of the scarecrow and just like you, I prefer the laid out wrap around version. It looks like your really close to landing it at this point, and when I was learning this trick I must have done a million of what your doing right now.. My advice to you is to jump with your knees. It will help you ride out the entire wake, and help you pop much harder. I think it helps because its really hard to tell with the scarecrow when excactly to release the board, but a little jump when your releasing from the wake will give you some height to work with. Stick with this trick because your really close. When you figure out the pop, you'll be able to see the water way before you land.
