I know it sounds ridiculous but if you do a raley right it is honestly one of the easiest tricks in wakeboarding, doing a raley on the water is completely different from doing one on the tramp. If you try to jump up and then kick youre legs out like on a tramp you'll never get the board back under you. Male sure to stand super tall while you cut in, don't crouch at all. Think about youre whole body being stiff and leaning away from the boat (bend your knees a little bit if you have to but not much), also cut as hard as possible, as Tye said above it's all or nothing, and the nothing part hurts. The main thing is to really cut through the wake, don't back off at all. If you cut correctly for this trick the you don't even have to do any work to get the board behind you and pulling it back down will be almost effortless. Also when I was learning these I was told to look down the rope at where the rope attaches to the tower when I left the wake, this helps to keep from freaking out in the middle of the trick because you're not looking down thinking about how much it's gonna hurt if you let go. start as far out as you want just what ever you do don't back off the cut and for goodness sake don't ever, ever flatten off b4 you hit the wake on this or you will be in a world of hurt. Let us know how it goes. Good Luck.
