Old    jeffrey buchanan (eliotflydog)      Join Date: Jun 2007       06-27-2007, 7:03 PM Reply
when i try whirly birds im either under rotating on the 360 or when i come around the roap gets ripped out of my hand wat am i doing wrong
Old    Nick C (wakedude83)      Join Date: Apr 2004       06-28-2007, 6:47 AM Reply
You are probably taking off early. Make sure that you are doing a tantrum before you throw the rope over your head. Make sure that the first move with your head is straight back. You don't want to look over your back shoulder off the wake. Sometimes taking a little more aggressive cut can help too.
Old    jeffrey buchanan (eliotflydog)      Join Date: Jun 2007       06-28-2007, 11:24 AM Reply
thanks
Old    Jon (socalf150rider)      Join Date: Jun 2006       06-28-2007, 4:05 PM Reply
WHAT THE FALLS LIKE ON THESE...
Old    jeffrey buchanan (eliotflydog)      Join Date: Jun 2007       06-28-2007, 4:14 PM Reply
Not too bad mostly slide outs and you occasionaly catch your front edge
Old    Jon (socalf150rider)      Join Date: Jun 2006       06-28-2007, 4:20 PM Reply
GOTCHA...wht kinda edge do u take into them. (never tried one but not far from it)
Old    B.C.P...........Mike (wakeeater2003)      Join Date: Mar 2004       06-28-2007, 4:33 PM Reply
The falls can be rough if you get caught up because you have momentum of the rope pile driving you into the water. I used to do them all the time but havent done one in a while mostly because i don't really like the feeling. If you have a tramp that is your best bet. If you are willing to take the falls you can land it relatively quickly. Later, Mike}
Old    jeffrey buchanan (eliotflydog)      Join Date: Jun 2007       06-28-2007, 6:38 PM Reply
i take a edge like a tantrum but i cut a little bit harder before i level off to throw the trick
does that make sence?
Old    Nick C (wakedude83)      Join Date: Apr 2004       06-29-2007, 6:50 AM Reply
It could make sense, depending on your riding. That's actually what I needed to do when I was learning. Some people don't have any trouble with timing when they learn it and can do it with an easy cut. If you are over-rotating, that is a better sign than if you are under-rotating. Under-rotating is definitely a timing problem and you need to wait longer.
