Old     (spenchey)      Join Date: Dec 2006       12-09-2006, 6:01 PM Reply
I need some tips to take my tricks further into the flats.thanks
Old     (monroeyd)      Join Date: Jun 2006       12-10-2006, 10:00 AM Reply
Edge harder
Old     (livigno)      Join Date: Aug 2005       12-11-2006, 5:29 AM Reply
Edge harder and hold your edge all the way through the wake. Pop from the TOP of the wake by really pushing your board against the wake by extending your legs. This will take you up AND out! Landings will be smooth, if the approach and the take off are done correctly.
Old     (byrd)      Join Date: Dec 2005       12-21-2006, 12:37 PM Reply
You probably need more speed. If everything else works ok, more speed gives you more distance.
Old     (bdeisel)      Join Date: Mar 2007       03-31-2007, 8:57 PM Reply
My riding style really involves a lot of speed to the wake. But when you do this you have to concentrate on keeping that same form You use when going for pop. Try to avoid bad habits like flattening off before you get to the wake. Throwing tricks into the flats are way cool but the landings are tough on the knees.
Old     (premierwake136)      Join Date: Jun 2005       04-01-2007, 7:46 AM Reply
spend a day with kieth lynman (jk)
what helped me was ovcourse alot of speed but the main one was not ollieing off the wake
like oliver said just push off the wake by extending your knees
and dont be croched over
Old     (hawk7)      Join Date: Apr 2007       04-13-2007, 3:51 PM Reply
yea and if none of that stuff works put more weight at the bow of your boat.
