Old                09-06-2006, 6:10 PM Reply
Got em dialed one wake now-how do you take it bigger without much more line tension.
Old     (tparider)      Join Date: Aug 2003       09-06-2006, 9:07 PM Reply
keep the rope super close on take off and use an ollie edge up the wake. Pull with both hands just in case.
Old     (rourker)      Join Date: Jun 2006       09-12-2006, 4:33 PM Reply
remember to concentrate on pushing your hip toward the handle at the apex of your jump. This will help you stay in a stable on axis position as you reach for the handle.
Old     (scott313)      Join Date: Jul 2006       09-14-2006, 5:33 PM Reply
Take a long mellow cut to keep the line tension down. It also helps to let off your edge on the wake and ollie straight up. Pull the handle hard to your back hip, that should give you the slack to pass. Good Luck
