Old    Taylor Walsh (Fluffytoasters)      Join Date: Mar 2013       10-25-2013, 11:54 AM Reply
Hey everyone, I have just learned how to do a 360 but I am not consistent because the line has a lot of tension. I have tried a small progressive edge into the wake but then I don't have enough speed to clear the wake and end up casing it. if I go hard into the wake and then lay off my edge a lot before I hit the wake, will this create slack?
Old    Dallas Cowboys #1 Fan Robert T (cwb4me)      Join Date: Apr 2010       10-25-2013, 2:33 PM Reply
You want to squat alot more and use your legs to create height. A wider cut will help build speed to the wake but the flat edge at the wake lessens the line tension.What line length are you riding at?
Old    Austin Ferguson (ferguson911)      Join Date: Sep 2013       10-29-2013, 8:07 AM Reply
As mentioned above a more squatted position will help. Also another thing to help you greatly! When you begin your pull on the handle it should be a 2 handed pull. If you begin your pull with 2 hands as long as possible it make a huge difference!
Old    Justin Harrelson (skiboarder)      Join Date: Oct 2006       10-29-2013, 8:18 AM Reply
You don't want slack. You want to never let the handle get away from you. Once it is gone…its gone.
One of the most common mistakes on a frontside 360 is people try to go from an edging handle position straight to their back hip. Try pulling the handle to your lead hip first (like a regular wake jump) and then across your body. It will make a big difference. It is easy to get away with the short cut on a 180, but it can be a huge problem for a 360.
Old    Taylor Walsh (Fluffytoasters)      Join Date: Mar 2013       10-30-2013, 10:15 AM Reply
Thanks guys
