Old    Ted Dickman (tdickman4)      Join Date: Feb 2013       04-05-2013, 4:56 PM Reply
I just bought a 2012 slingshot recoild and put my 2011 ronix cells on it. There is a little rock on the bindings, is that ok?
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       04-06-2013, 9:43 AM Reply
Hi Ted.
Ronix bindings, unfortunately sometimes end up having a little bit of rock with them. I've got a 2012 Kine with 2011 Ronix Cells, and they've held on there extremely well.
My only recommendation is make sure those suckers are LOCKED onto that track. That'll be a big help.
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       04-06-2013, 9:45 AM Reply
Here's some ideas on how to lock those boots down best.
http://www.wakeworld.com/forum/showthread.php?t=795203
Old    Ted Dickman (tdickman4)      Join Date: Feb 2013       04-06-2013, 11:40 AM Reply
Locking them tight is just pinching them as best as you can to the board, correct?
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       04-06-2013, 12:07 PM Reply
Exactly, Ted.
The Ronix boots have those little binding teeth and the rubber tooth inserts, and the Slingshot cap and anchor pieces you would use to attach the boot to the fast track are designed for the flat surface you'd get on a Slingshot boot.
I posted the link above to give you a few ideas on how to get those Ronix boots on your board as tight as possible. I'd recommend what was done in this picture (pulled it from the link posted above) Without doing that, your odds of those boots loosening, sliding, etc... are a bit higher. This ensures more mounting hardware to boot contact.
