12-11-2012, 7:24 PM
Well its been 6 years Since my last polish
http://www.wakeworld.com/forum/showthread.php?t=282492
The Boat has seen alot of action in 6 years and it was time to have at it all over again. This time I had got turned onto a few new products and had a chance to try them out. Lucky for the boat owners I think the new compounds and Polishing pads make it easy and faster to do then when I did it 6 years ago. So lets get started. Step 1 Take you Whole boat apart!
12-11-2012, 7:27 PM
This Picture will give you a idea of the finish's Im working with.
The Area under the Gas cap has never seen the light of day.
The Area around of the Gas Fill Area was the finish I started with.
The Top of the deck was a quick 1500 wet sand and Polish
12-11-2012, 7:41 PM
This is the System I ended up using and it works great. Most surface scratches can be removed with 1000 or 1500 wet sand. If your a pro you can use 600 or 800 and wrk you way up but if your not a pro you cant get into to much trouble with 1000 or 1500. These 1000 and 1500 wet sand marks can be taken out with Perfect-It™ Machine Polish, in a matter or moments. So if you don't have any scratches you can skip the sanding part. But if you has some small scratches wet sanding them out will cut your buffer time in 1/2 and the finish comes out better, But I understand if you don't want to touch you boat with paper.
Here is a pic of the 3m Perfect-It™ Machine Polish,
This stuff is white and feels to the hands like it has Zero grit to it.
You use a wool pad with this stuff and you have the buffer on medium or like 1500 rpm's
Keep the surface cover and work in small section's like a 2 or 3 foot section. Work the material into the gell till its all gone and you start to see a polish. THEN STOP
more info here
http://solutions.3m.com/wps/portal/3...gl4XF802T6Q3bl
12-11-2012, 7:54 PM
Next Step. Put some of the 3m Machine Polish on a small clean towel and use the 3m Machine Polish to remove all the remaining material. Once the boat is all clean and you have got all the polish off the boat your ready for the next Step.
I used these pads with the Finishing Material.
You lower the speed on the buffer to like low or 1000 Rpm
This will give you a very nice finish.
http://solutions.3m.com/wps/portal/3...gl6LGQDSV291bl
12-11-2012, 8:05 PM
Then I used 3m Hand Glaze. This Hand Glaze has the ability to give the gell color. Example if you have a black boat it will start to lighten up or turn white. The oils in the Hand Glaze will add color or restore color to the gell. If you can apply the Hand glaze and let it soak in over night the oils in the glaze can soak into the finish and add color.
You MUST wax over the top of the hand glaze to lock in the color. The Hand Glaze has NO Wax in it
and will be gone as soon as you wash it a few times. The wax will "seal in" the color.
Wax is a Personal thing so use what you think works best . I like the Meguiar's Marine Wax for the same reasons I like the Hand Glaze it seems to add color threw the use of Oil's its easy to apply and take off.
12-11-2012, 8:07 PM
Here is what the finish looks like so far
12-11-2012, 8:08 PM
more
12-11-2012, 8:10 PM
Here is a polished section
12-11-2012, 8:13 PM
If you notice My whole garage is taped off and Plastic is everywhere. These Compounds and Wax's get everywhere. Once they are dry its a PITA to get them gone so IMO its easyer to spend a few Hrs taping everything off and protecting the walls and other surfaces. That includes your trailer.
12-11-2012, 9:08 PM
Incredible looking finish... Man how do you find the time to get all this done? Thanks for sharing a lot of good info over the years! Just curious how many man hours did this take?
12-11-2012, 9:25 PM
Brad: Last year I started my normal winter time project's and I got a little over zellous. B4 you know it I had the whole boat pulled apart and and a "To Do" list that was huge. I worked on my to do list untill May. Then we got a New boat and the summer came on and the boat was on the back burner. So this winter The boat was already apart and I had most of the Mechanical To Do's done. So with all mechanical out of the way It was time to start cut and polish. Now that cut and polish is out of the way. The Pin Stripe is going back on and then The new Rub rail will get installed, Then its time to move inside and install the floor and start putting her back together, The only thing left to do is everything
12-11-2012, 11:20 PM
Looks great G! I have some pretty heavy oxidation on the outside of my boat and am contemplating doing it myself or having it done... How much time do you think you have into just the wet sanding, polishing, waxing part of the project? I probably wouldn't go into the interior or strip the boat as you did. Having never done any polishing/wet sanding before I'm a little apprehensive, although I'm pretty handy and pick up on things fairly quick.... Would you say it's rookie friendly project? I reviewed your last polishing project earlier in the summer but decided to hold off as some other projects took priority
12-12-2012, 6:48 AM
Detox. I would tape off and try a small section yourself. If you could do the transome and be happy with the results I would say that you could do the whole boat yourself. The 1000 & 1500 gritt paper is not very aggressive so it won't get you into to much trouble. The machine polish is easy to work with and removes small scratches pretty well. I would say the better you are with the polisher the less you can depend on the wet sanding. The more items you can remove from the boat like grab handles ect the easier it is to do and the better the over all project comes out ( but it takes more time) I would say most people would not want to pay what it costs a pro to do Somthing like this. You can spend 3 to 4 grand no problem doing what you see me doing here in this thread. I would say the deciding factors weather you should try Somthing like this is. Do you have a Garage that's well lit? Can you deal with your boat being pulled apart for a few weeks? Do you or can you make time?
I would say 2 weeks is what you should give yourself for a project like this. I would say you can spend a full day just prepping (masking off your boat and garage) and another 3 or 4 days sanding small scratches and polishing and then another few days detailing and cleaning up.
12-14-2012, 12:49 PM
That looks great. Totally jealous that you have a garage to house your boat. Nice work!
12-15-2012, 6:47 PM
Grant, may I suggest that if he doesn't feel safe sanding, he can get a Cutter to equal the 1000 - 1500 grit wet paper? Apply it before the machine in the place of sanding...
12-15-2012, 8:37 PM
True: that's a good Idea. What cutters would you recommend. Only cutters I have used is 3m Super Duty compound.
12-15-2012, 9:05 PM
You can use a 3m medium cutter compound, boat candy crystal cut compound ( my favorite at the moment due to polymers), or meguiars ultimate compound for lighter grit...
12-16-2012, 5:14 AM
Oh also, when your compounding or polishing, use a damp micro fiber cloth instead of more polish to remove the excess build up as you travel from section to section. It may be easier than trying to use polish to to remove the excess due to having to elbow it dry. Water is a wipe off wipe dry kinda thing
12-17-2012, 6:47 AM
Grant what buffer machine do you use or would recommend?
Sent from my EVO using Tapatalk 2
12-17-2012, 9:23 AM
"G"
You take waxing your boat to a whole new level.
Looks great!
12-17-2012, 11:02 AM
What boat did you get?
12-17-2012, 2:15 PM
Has anyone bought any of the boat candy product? I am interested in some of their stuff for my faded boat.
12-17-2012, 4:41 PM
And you can't not do the bottom!
12-17-2012, 4:43 PM
Taking all the bits and pieces off is where more than 1/2 of the time spent go's
12-17-2012, 6:20 PM
Looks great Grant!
12-18-2012, 10:35 AM
Another advantage of removing the miscellaneous items around your boat is You don't end up with a halo around the parts Plus it's easier to run the buffers over a smooth flat surface rather than work around parts
12-28-2012, 4:42 PM
amazing work and attention to detail. not many people like you roaming the planet. i could not imagine the cost for a shop to do what you have done and i promise no shop would do near the job and take the time to remove parts and protect tower and trailer.
good job
02-05-2013, 5:48 PM
I have a few questions. Could I use a 6" orbital with a foam or wool cutting pad or would it be better to use a regular variable speed polisher instead? I have ghosting from the Maristar sticker I removed from the side of the boat as well as some fading on the black striping. Maybe it's oxidation I don't know if there's a difference on gel between the two. I did a test spot using meguires heavy oxidation remover and a cutting pad with the orbital to remove the ghosting and it definitely improved with more effort than I would have thought but still exists. Any help would be appreciated thanks
Reason: Jk
02-05-2013, 6:46 PM
Wow, that is awesome work!
02-05-2013, 8:30 PM
02-17-2013, 6:06 PM
bump....
I have a few questions. Could I use a 6" orbital with a foam or wool cutting pad or would it be better to use a regular variable speed polisher instead? I have ghosting from the Maristar sticker I removed from the side of the boat as well as some fading on the black stripingg (maybe it's oxidation I don't know if there's a difference on gel) I also borrowed a variable speed so i guess the question is what would be the best way to go about removing the ghosting and doing the rest of the boat as well
02-17-2013, 6:22 PM
Im curious to this too. How did you get your decals off? Heat them up with a blow dryer or something?
02-17-2013, 6:50 PM
you cannot typically reapply decals... once you have peeled it off, its off.
02-17-2013, 8:10 PM
I must have quoted my post wrong  I was just curious how to get decals off. I tried getting my registration stickers off and they werent wanting to come off with just a razor knife. And I was kicking around the idea of removing my decals too and I figured Id have the same fading that'll need buffed out. I wasnt trying to hijack his question. Just curious how he managed to get the decals off.
02-18-2013, 4:54 AM
Heat gun and googone with that plastic scalpel tip is what you need. Just don't get the hull too hot and don't scrape too hard. Just go slow and let the googone do its job dissolving the adhesive.
02-18-2013, 8:32 AM
Bass10after; I would attack the Ghosting with 1000 or 1500 grit wet sand. That way you can be sure your going to get it all out. It's hard to evenly remove oxidation with a buffer. This way you can skip the compound step and go straight to micro fine polishing compound. Your buffer time with be cut down to almost nothing.
Bryce: I used a heat gun to remove pretty much anything that's stuck to the boat (with the exception of registration stickers) if you try and heat them up the top clear coat comes off best bet is to get them room temp or outside temp " in the sun" and they will peel up no problem and can be put back on. I left my CF numbers on. I doubt u could remove them with out damage
02-18-2013, 12:01 PM
bryce i used my girlfriends hair dryer and some 3m adhesive remover for mine. i found there was a very delicate balance between hot enough to remove the decal and most of its adhesive in one piece and too hot which the decal would just break apart and leave me with a mess. Once i found that balance the process went pretty quickly considering the boat is a 99 with original decals.
02-18-2013, 12:02 PM
g, would you recomend wet sanding by hand or using an orbital for that part?
02-18-2013, 4:24 PM
Hand sand and a rubber pad . Start with 1500 ( you can't do to much damage) with 1500 by hand and as u get comfortable you can drop down in grits. Example the lower grits like 600 and 800 you better know what ur doing because they cut much faster. So if ur a newb start out slow and learn the process as you become better you can learn how to cut corners and do it faster
02-18-2013, 5:33 PM
grant, great looking boat, quick question, why did you choose to hand sand and polish, a buffer and buffing compound would give the same result and probably take hald the time, when i worked at a fiberglss shop before the navy we could knock a boat out in an hour or so with the power buffer, heres a little before and after of a boat we did when i was there 2 years ago
02-18-2013, 10:14 PM
Kyle; I recommend Hand Sanding and Machine polishing.
Some one asked what polisher I recommended. I use a variable speed Mikita but any quality variable will work just as good.
02-25-2013, 8:25 PM
Just finished up this project, wanted to say thanks to grant and everyone else who chimed in as well. I ended up wet sanding out the ghosting areas followed by 3m superduty compound, then finesse-it II, then meguires NXT generation 2.0 wax. Took me three solid days probably close to 30hrs to complete. I didn't break everything down like grant did, as i don't have a dedicated shop and am at the mercy of our nice weather at the moment. Also got some good advice and materials from b&z auto body in modesto. solid shop with good help and had many different compounds to choose from. i ended up going with the compounds and wax that the employee recomended as he'd done some boat restorations as well. My back hurts, my knees hurt but my boat looks brand new and the pain never felt better.
02-25-2013, 9:24 PM
I did mine last year and it came out great!
Tools of the trade... 3m Super Duty rubbing compound, 3m Finesse It II polish, 3m Marine Ultra Paste Wax, Makita 9227C buffer, wool and soft polish pads
That picture is after a quick first shot at the transom. You can see it was getting dark so I didn't finish that night. The whole transom looked like the small parts of oxidized white towards the bottom. That was just after the rubbing/cutting compound.
I believe this was after polishing and before wax.
This is some time after a few times out.
Bang for the buck a good compound and polish is about the best thing you can do to make aging gel look great again. If you have any fading or oxidation I highly recommend it. It's a lot of work, it took me a few days to do mine and I didn't go to the same extent as Grant by removing all hardware and getting every last spot. It still took me a full day and a few evenings after work.
02-26-2013, 9:58 PM
That's unbelievable work! Thanks for sharing.
05-12-2013, 12:15 PM
Grant,
I last did mine when you did yours. Now I have the problem of having transferred cross country and the boat wrap left small scratches on the bow gunnel that are just deep enough to catch a finger nail!  I was tossing the idea that 1000 grit wet sand I can get them out without breaking through the gel...Then I'm going to continue with the steps of moving to 200 grit, 3M super duty compound, 3M Finesse It, Glaze and final wax. Wasn't sure about using a wool pad with the compound step or using my W7000 Meguires cutting pad like last time. Whats your thoughts on the scratches?  Thanks
05-12-2013, 6:26 PM
With 1000 grit ur gonna be their all day "but" your pretty sure to do no damage.
I would take 600 grit to it till the scratches are 99% out then go 800 1000 1500 then micro fine and your good to go each time you change grits go a bit larger in your sanding spot. Start small with a pad with 600 and get larger.
05-12-2013, 7:23 PM
Is there any way to judge how thick the gel is so I don't break thru? This is the first time paper to the boat but I am experienced with clear coats on cars so wet sanding is not new to me. And how big of an area do you recommend around the scratches so that there are no "high-lows" in? Thanks By the way every time we end up transferring back to a cold weather state the wife always makes sure I didn't sell that red boat blanket we got from you years ago!
05-12-2013, 10:29 PM
If you have any holes in your boat that you can see the profile of what u drilled threw you. Can get a idea how thick the gell is
05-15-2013, 6:30 PM
Yeah, about that.... only holes are stuff like cup holders, things in the cabin/crew area, kinda sol on that. I never did any drilling on her.
05-15-2013, 7:19 PM
Most boats I've seen have the gelcoat finish thickness of a credit card Here's a small piece of my NuTeak on the right and a credit card on the left
05-15-2013, 8:19 PM
Thanks that picture does help. So since I still see white in the deepest of scratches, I should be able to get them out without going through the gel, correct? If I start to break through I would see another color than white? Thanks
05-16-2013, 4:12 PM
Ghost: I would hate to tell you to keep going. Only for you to burn through your gel. When you start getting really thin the gell can become translucent. So you don't half to burn through Sometimes to notice a color change. Typically what I do Is I try and remove the scratch 80-90% Through sanding
The remaining should polish out. However some people feel they have more control with the sandpaper And they choose to remove the scratch completely Through sanding And then they only have a little bit of work to do with the polisher.
Yesterday, 7:52 PM
Grant - started the wet sanding and its going great but since this the first time I have allot of work ahead planning on it taking 2-3 days of sanding alone. Did you replace using a rubbing compound with that machine polish? If so why? My steps were going to be like the last time - 3M rubbing compound / 3M Finesse It / Glaze / Wax.
Thanks
| Thread Tools |
| Display Modes |
Linear Mode
