You will drill the holes where you want on the top of the tower, then drill your hole on the base of the front bar ( right above where the tower connects to the side support bar)new ones you can skip drilling but will still need a quick connect that fits inside the tower cavity, then you will drill a hole in the top front support bar and also drill a hole at the base ( above the weld).. Then locate where you want to drill thru on your hull and double check to make sure that's where you want it and that you have access inside.. Then run your wire down the tower and out the first base hole, leave excess. Now run wire thru the support bar hole and leave about a foot at the top of the support bar and the length you think you need to go inside and connect to whatever's location.. Now where you left excess ( between base and tower upper) you will put some style of quick connect... Use heat shrink where you can to seal any connection, also make sure to clean all drill holes smooth with a file... you can use grommets, any style of loom to make it as professional as you deem necessary.. Help?
