Old     (rexlex01)      Join Date: Mar 2010       07-30-2012, 4:35 PM Reply
See link below to a non-marine amp, but I live in midwest on fresh little lake and amp will be mounted up and under a closed bow and was wondering if there was a better amp for the money running 2 inboats polk db651's and 2 tower JL MX650's? Dont care for major bass.
http://www.ebay.com/itm/CADENCE-ZRS-...item46042308d2
Old     (King12)      Join Date: Jul 2012       07-30-2012, 4:56 PM Reply
Be careful and note that that amp is running on a 16v power supply
Old     (King12)      Join Date: Jul 2012       07-30-2012, 5:08 PM Reply
Are you looking for a certain amount of power per channel and is there a certain RMS amount you dont want to go under?
Old     (rexlex01)      Join Date: Mar 2010       07-30-2012, 5:18 PM Reply
I would like to get the most RMS, right?
I know very little about electrical. obviously
Old     (rexlex01)      Join Date: Mar 2010       07-30-2012, 5:22 PM Reply
http://onlyinboards.com/AccessorySho...-Speakers.aspx
http://www.amazon.com/Polk-Audio-6-5...rds=polk+db651
Old     (King12)      Join Date: Jul 2012       07-30-2012, 5:58 PM Reply
Well not necessarily the most RMS is the best. I doubt you will be playing your music at full blast all day all the time, with the amp at full power all the time and if so it probably isnt going to sound the best after a while. and Your amp probably couldnt take it even if it was a great amp. But 600 is pretty good id say not a terribly high amount but should get plenty loud.
but what youre also having to look at is the output per channel. THose JL audio speakers it says have a max RMS power handling of 60w, and the Polks it says 180 but it never says RMS so im assuming thats max output not RMS which is constant.
I dont know anything about Cadence amplifiers, unfortunately, but i would be very cautious about hooking one up to such nice speakers. It VERY WELL may be a fine amp, ive found a few good reviews about it. But its hard to be sure, with it being a more unknown name. I would say it would be like going out and buying a really nice ronix or LF board and then getting ebay boots?
http://www.amazon.com/JBL-MA6004-4-C...nnel+amplifier
I would recommend something like this, solid company, good reviews, probably outlast the cadence, and 60w rms which is your JL's max RMS output.
plus its prime if you have a prime account
But end the end only you can decide if you want that amp or this one or any other one, im sure the other is a good amp. But its also worth something that with this amp you can deal with amazon if its shotty or malfunctioning, where as the other you deal with the seller
Hope this helps a little!
Old     (rexlex01)      Join Date: Mar 2010       07-30-2012, 6:48 PM Reply
thanks
any other brands that are a better deal other than $20 off of retail?
Old     (chpthril)      Join Date: Oct 2007       07-30-2012, 8:17 PM Reply
Cadence Audio has been around for awhile, just not widely distributed.
http://www.cadencesound.com/
If those specs in the Ebay link are accurate, then that amp will be fine power wise for you.
Old     (King12)      Join Date: Jul 2012       07-31-2012, 8:08 AM Reply
looks like youre good to go! Hope it serves you well
