Old     (andrew_moreton)      Join Date: Feb 2003       07-21-2012, 4:36 PM Reply
Does anyone use the Straight Line Sumo Bags instead of Fly High Fat Sacs? The are a little cheaper, but wanted to know what people thought of them before purchasing. Do you have to use the Sumo Pump or do they use the same fitting as Fat Sac where you can use the Tsunami pump? Any input is much appreciated. Thanks in advance!
Old     (boardjnky4)      Join Date: Dec 2011       07-21-2012, 4:53 PM Reply
I use them. You'll need the sumo pump. I've had no issues. The hold water and dont leak. Also, I prefer the link valve to the fat sac quick connect since it doesn't let water out when you pull the pump off.
Old     (wakeboardern1)      Join Date: Aug 2007       07-21-2012, 5:36 PM Reply
What Tom said. They are what I use... Although they're definitely a little more prone to splitting than Fly High stuff. You can patch them real real easy though with just a little vinyl repair stuff, like what you use for air mattresses. Plus I have a tendency to wander off while filling them, so it's really my fault that they have holes in them. Haha.
Old     (MrShelley)      Join Date: Apr 2012       08-01-2012, 3:17 PM Reply
You can use the Sumo pump with Fly High bags, and the Fly High pump with Sumo bags, you'll just need an adapter.
Old     (boardjnky4)      Join Date: Dec 2011       08-01-2012, 5:30 PM Reply
yep, wakemakers carries the adapters, good point
Old     (MrShelley)      Join Date: Apr 2012       08-03-2012, 2:48 PM Reply
FWIW, the Sumo pump comes with this adapter to fill Fly High bags.
http://www.wakemakers.com/launch-pad...d-adapter.html
