Old     (ScottR)      Join Date: Aug 2011       01-27-2012, 8:16 AM Reply
Trying to figure out how to do this..... no where to buy it, can't find anything about it anywhere. Found the picture online. Have the glass top and wondering best way to build this.
Is it whole pieces for each?
How is it held together on the bottom?
Old     (baitkiller)      Join Date: Jan 2010       01-27-2012, 8:29 AM Reply
You need a buddy with a CAD program and a pattern router. Or a bunch of time. Has to be section plates. I would think the inside sections would be center less or it would weigh a ton.
Old     (0klahoma_Breakdown)      Join Date: Mar 2010       01-27-2012, 8:53 AM Reply
Are those sections metal? You could substitute particle/laminate and make the bottom in two separate sections separated in the very middle. It would still be heavy but at least manageable.
Old     (jonblarc7)      Join Date: Jul 2006       01-27-2012, 11:02 AM Reply
My guess would be you start with the out side panel then using a smaller block to seperate the next panel. Then that panel is screwed and glued on the smaller block and so on and so on. Then I would leave the center 5 or so panels to be screwed from the bottom. It looks like to me the panel on the floor is just half laped by the vertical panels, you could screw the panels from the bottom too to make it extra strong. No need for a router you can do it all on a table saw.
If you want I can draw it up for you on cad and send it as a PDF. It wouldn't be hard at all to draw, furniture design is what I do for a living.
