I would fill up the front surf side only, and verify it fills. I have seen the front ballast not fill even though pump is running, it doesn't prime, check that. No water in opposite side front. Then fill the rear surf side til the rub rail is about 2 inches off the water with your peeps on surf side. When you get to 11 mph or so, you should see the rub rail kissing, if not, add a bit more to that sac. My guess is that you only need 600-800 lbs in that rear sac to kiss the rub rail. Then adjust speed to taste. RJ likes a bit over 12mph, and others usually around 11mph. Check with your iPhone GPS if you need to. See how that works, and post some pics. Oh, also put the taps all the way down. The shorter tige boats have a steeper transition, which makes it hard to turn in and out of the wake and do 360s and stuff. Put taps all the way down to smooth that out. Anyway, post the pics. ;-)
