Old     (tbb1798)      Join Date: Mar 2010       05-17-2010, 6:40 PM Reply
What do you use for the top of a funbox.....
Old     (hyperlite)      Join Date: May 2009       05-18-2010, 4:16 AM Reply
trex......or pvc sheets.
Old     (gknott)      Join Date: Jan 2010       05-18-2010, 6:37 AM Reply
HDPE. Something thin is all you need, like 1/8-1/4", if there is a plywood base. If there is no plywood base you should use like 1/2"
Old     (the_fish)      Join Date: Jun 2009       05-18-2010, 10:36 AM Reply
This
Old     (hyperlite)      Join Date: May 2009       05-18-2010, 11:28 AM Reply
also make sure all your wood is PT. otherwise youre wasting money cause your shizzzzz is going to rot fast
Old     (jbwaken)      Join Date: Dec 2005       05-23-2010, 11:38 AM Reply
i have 1/2" 3x7 white poly pro sheet that seems to work great.
Old     (wkskbk)      Join Date: Apr 2010       05-25-2010, 5:32 AM Reply
www.RailWerx.com/armorgrind
Check out this stuff, I am building my slider with this HDPE/ALuminum
This is an aluminum backed plastic. You screw down the aluminum, then slide on the plastic over the top of the screws.
Old     (chrishopf)      Join Date: Sep 2007       05-25-2010, 6:07 AM Reply
anything plastic under 1/2inch thick will bubble in between srews once layed out in the sun.. I would recommend using 3/4-1 inch thick if you can afford it, and Treated Wood is a must for long term hits!
CH
