Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 28, 2009
Old    Doug (supradoug)      Join Date: Dec 2001       06-06-2009, 4:55 PM Reply
I want to put the starting battery on #1 perko switch and 2 optimas on #2 perko. how would i hook the 2 optimas? pos to pos and neg to neg, then cable to perko? and can i gound with the starting battery?
Old    Hate N Pain (hatepain)      Join Date: Aug 2006       06-06-2009, 5:58 PM Reply
Yes on the first and you should ground your stereo from the house bank. All your grounds should be on the same battery.
Old    Doug (supradoug)      Join Date: Dec 2001       06-16-2009, 9:13 PM Reply
ok I have it set up with the large cable from the alt going to the "both" switch on the perko and the engine block ground going to the starting battery. Can I use the smaller cable going battery to battery or do I need to use the big stuff that comes from the engine? THanks
Old    Ryan Bush (ryanbush11)      Join Date: May 2003       06-16-2009, 9:55 PM Reply
anything 4 gauge or bigger and you should be fine
