Sure thing chad, When I started trying these it was my first toeside invert, I couldnt even jump ts w2w yet. What I would do is come in hard, then huck it at the wake. I actually learned to land them, but was definitely not a smooth way. I spent alot of time over rotating it, and smacking my back. What really helped me to get this down smooth, was to take a few good toeside jumps wake to wake. Get the feel of riding to the top of the wake and getting the pop. Then go for it. What you need to remember when coming in is to keep BOTH hands on the handle, and keep the handle tight to your front hip. When you hit the wake, it should be just like your toeside jump, make sure and ride all the way to the top. once you hit the top initiate your roll. Think about going up in the air and not across both wakes. If you get the pop correct, it will easily carry you. AFTER you begin your roll, then release the handle with your back hand (otherwise you will be pulled to revert). Spot your landing and try to land edging away. good luck with it man, my biggest things I started out doing wrong was letting go of the handle with my back hand at the wake, and not riding it all the way to the top. If you do it right, it will happen really smoothly. This past week I tried taking it to revert, and picked it up in one session. It is really an easy thing as well, plus you land with two hands on the handle making your landing a little stronger. Good luck with it man, hope this helps
