Well, here's my setup (so far). In the boat I have 4 Polk 6.5's mounted. I also have 4 Polk 6.5 Tower speakers and a 12" Polk momo sub. To power this stuff I have a Clarion APX480M (4 channel amp). and a Rockford Fosgate P5002 (2 channel amp). Without purchasing more stuff, what is the best way to set this system up (i.e. which speakers to what amp, how many batteries, and any other recommendations) Down below are all the specifications on all the stuff in case it will help with your recommedations. Thanks a lot for the help! Rockford Fosgate P5002 Amplifier Number of Channels 2 Rated Power continuous power 125W x 2 @ 4-Ohms RMS 250W x 2 @ 2-Ohms RMS 500W x 1 @ 4-Ohms bridged RMS Total Power total sum of 'rated power' 500 Watts Bridgeable Yes Crossover Controls High-Pass (HP): 40-400Hz 12dB/octave Butterworth Low-Pass (LP): 40-400Hz 12dB/octave Butterworth Tone Controls Bass: 0dB to +18dB @ 45Hz Signal Input Low level: 1 RCA pair Signal Output Low level: 1 RCA pair Power Input Connector Block Power Wire Gauge 4 AWG Speaker Output Connector Screw terminal barrier strip Speaker Wire Gauge 8 AWG to 18 AWG Heat Sink Type Cast aluminum Cooling Convection Remote Controls Punch Bass EQ (included with cable) Visual Indicators Power On Signal Level Thermal Status Speaker Protection Circuit Topology Class Class A/B Frequency Response 20Hz to 20kHz +/- 0.5 dB Clarion APX480M Technical Specification • Number Of Channels: 4 • Maximum Power: 640 Watts • Built In Crossovers: Yes • Channel Separation: Yes Features • 640 Watts of Maximum Music Power • 80W × 4 Into 4 Ohms, 20Hz-20kHz @ .05%THD • 115W × 4 Into 2 Ohms, 20Hz-20kHz @ .2%THD • Variable Bass Extender, 0-15dB @ 45Hz • Adjustable -12db/Oct. High/Low Pass Crossover, 55Hz-550Hz • Mixed Mode Operation • Conformal Coated Double Sided PCB • Fully Painted Non-Corrosive Aluminum Heat Sink • 13"(W) × 8-1/4"(D) × 2-1/8"(H) Polk 6.5 Speakers Power RMS power handling (watts) 60 Frequency response (kHz) 35Hz - 22kHz Peak power handling (watts) 180 Recommended amp wattage range Info unavailable Peak power range (watts) 150-249 General features Speaker size 6.5" Speaker type 2-way Speaker Directional tweeter Manufacturer's part number DB651 Polk 12” Momo Sub General Woofer Size (inches) 12 Woofer Material Aluminum ABS Enclosure Type Sealed Color Black Pieces in System 1 Width (inches) 14-5/8 Height (inches) 14-5/8 Depth (inches) 13-1/8 Second Depth (inches) N/A Connector Type Push terminals Frequency Response 20-200 Hz Power Range (Watts RMS) 200-500 Maximum Wattage 1000 Sensitivity 87 dB Impedance 4 ohms
