Provided you did not do any gel or fiberglass damage it should be pretty easy, though if you ripped the screws out you're going to have to make sure to fill the holes in so the screws will hold. Did you do any prop, drive shaft or strut damage? If you were shallow enough to hit a tracking fin you were shallow enough to hit the other underwater gear. I would definitally check into it, a bent drive shaft or strut can cause other issues down the line.
