please see this thread. <BR> <BR><a href="http://www.wakeworld.com/MB/Discus/messages/3183/591104.html?1213735341" target="_blank">http://www.wakeworld.com/MB/Discus/messages/3183/591104.html?1213735341</a> <BR> <BR> <BR>As I am asking, with a one wire alternator going into a boat originally wired for a 3 wire and upgrading to a 105amp, <BR> <BR>should I run a new power wire to the battery separate from the original wiring harness ? <BR> <BR>what exactly are the Orange, Purple, and Black wires for and where do they hook into ? <BR> <BR>can I just leave these unhooked or do I need to wire it any differently that it was the last 3 years with only the orange wire hooked in ? <BR> <BR>any help with these questions is much appreciated.
well I think I found my answer here. <BR> <BR><a href="http://www.wakeworld.com/MB/Discus/messages/65921/150339.html" target="_blank">http://www.wakeworld.com/MB/Discus/messages/65921/150339.html</a> <BR> <BR>someone spoke with Indmar and they were told to bypass all the original alt wiring and ran a new wire past the breaker and to the starter, not the battery like I was thinking.
just thought of another thing. <BR> <BR>If I later add an isolator for a dual battery setup where does the alt. wire need to come from that connects to that ?
Clint - it depends how big your stock wires are. You will need 4ga or bigger to get enough current to your battery and accessories but if your batteries are more than a few feet away you will need to increase the wire size to 0 or 2 ott. There should be a circuit breaker in your engine compartment that will need to be upgraded as well. <BR> <BR><a href="http://bluesea.com/viewresource/535" target="_blank">http://bluesea.com/viewresource/535</a>
