Amp Recommendations
Any thoughts on an amp to power 3 sets of Wet Sounds 6.5's and a JL 12w3?
Maximum Class D efficiency. Super high Class D switching speeds, at least 20 times higher than the audio bandwidth. Always meets or exceeds its 14.4 volt rating even at a lower 12.6 volt supply. Produces 97% of its 1 kHz power across the entire audio bandwidth. Lots of input configuration flexibility. Port for bass level control. All input and output terminals along one side with a closed chassis and covered controls. |
Don't mean to swoop on the thread, but David:
I am looking to take my current arc 600.2 that is running my two JL 10w3s sealed, and putting it to my Rev 8s. I currently have 4 rev 8s running on another 600.2, would like to have the two arcs for the tower...what JL XD is a good pair or similar to the 600.2? Currently subs sound really good and would like to keep the same power if not a tiny bit more... have used JLXDs in the past but am less familiar with them. |
Thanks David. What are your thoughts of running the same set up with an old PP 1000.4? Not ideal but not looking to drop another 6-800 if I don't have to.
That is an all Class AB amplifier and it is a real current hog. The original PPI was golden. But after being purchased by DEI they began to package the identical amplifiers in a variety of chassis by different brands. So I'm not sure which amplifier that is. But it will work. |
Thanks David! I should be finishing my system tomorrow.
The XD is a completely different animal with higher switching speeds, wider bandwidth, completely different input section, different features, all connections at one end, covered controls, plus all the added technology that distances JL Audio from its competitors. Each one has a place. |
