Wakeology
Anyone know anything about there binding setups would the 11 watson with the Integrated Lock Plate // AR6 Chassis work on the wakeology transit?
Mike I do not believe it will work without the extended Liquid Force clamp. I have the sick transit and to ride all the way out you have to have the binding clamp extenders. I knowLiquid Force, Ronix and CWB have a clamp for their bindings for this older hole configuration. I have a set of 2011 Hyperlite system bindings and Hyperlite doesn't have an extender clamp for their bindings. I tried all three of the clamps for the hyperlite and no luck
I have a old set of hyperlite spin bindings that have 8inch plates do you know if that would work? what is the width on your bindings?
Those bindings will be fine. The new 6 inch bindings won't work.
Thanks for the help Rob
